Torque converter and valve body install??
Old Apr 20, 2007 | 12:54 PM
straight_six's Avatar
Default Torque converter and valve body install??
Has anyone done it or know how hard they are too install??
Old Apr 22, 2007 | 02:09 AM
haha nobody???
Old Apr 22, 2007 | 03:26 AM
Longhorn's Avatar
Ive done it on a Ford 390 but not on our trucks...that one was 2wd as well. No problem...I would think a 4x4 would be a more of a challenge! Not hard but lots of labor...remember the pan gasket!
Old Apr 22, 2007 | 07:27 AM
Racer9's Avatar
You'll need a tranny jack, no way you'll lift that trans/transfer case. Simply slide the old TC out, fill the new one with about 3 qts of fluid, and slide it in, making sure the slots line up with the pump and it goes all the way in.
Valve body is fairly easy, except for the park rod clip, which is a real PIA!!!
Old Apr 22, 2007 | 06:51 PM
dieseljunkie's Avatar
Never done it.. Im the kind of guy that would rather pay someone to do it then tackle something like that myself... besides the fact that I don't have a tranny jack
Scott
Old Apr 26, 2007 | 06:11 PM
STOVEPIPE's Avatar
yeup done it, I used two trans. jacks one under the trans. one under the transferr case. It worked pertty good just took my time and did it right. turned the line pressure up and adjusted the shift points.
Tmaxxrox97
10
Nov 10, 2014 10:37 PM
