Starter Kickback
Old Jul 18, 2008 | 08:45 AM
bucky's Avatar
Default Starter Kickback
When I shut down there is a sound kind of like the starter is getting spun by the flywheel just a bit. It could be something else but I don’t have any idea what. Any thoughts?
Bucky
Old Jul 18, 2008 | 10:08 AM
wildbill's Avatar
Sound almost like a chirp?
Old Jul 19, 2008 | 09:25 AM
Mr.Krabs's Avatar
Yeah,describe the sound!
The belt chirps,and if you've got a large exhaust with a straight pipe you can hear the turbo winding down..
Old Jul 19, 2008 | 10:36 AM
bucky's Avatar
It isn’t belt squeal that I’m hearing. I’ve been hearing that for the past few thousand or so shutdowns and that sound hasn’t changed any.
What I’m hearing stops too soon to be the turbo. It kind of sounds like when the engine does the kickback on shutdown, it catches the starter gear and spins the starter just a bit. The sound will last for less than a second.
I’m headed out on a run to FL. today and I won’t have time to reply till I get back.
Bucky
Old Jul 19, 2008 | 11:50 AM
CumminsCrazed's Avatar
is there any way you could maybe video you shutting the truck down so we can hear what the sound sounds like?
Old Jul 25, 2008 | 11:31 AM
bucky's Avatar
I took off the starter when I got back from Florida and checked it out. The spring on the starter gear is very weak and I can see wear marks on the gear where it was hitting the flywheel when the engine shakes and kicks back during shutdown. I took it to the starter shop and the guy said not only was the spring shot the front bearing and housing is worn out.
Bucky
leocanuck
6.0L Performance
Sep 27, 2015 06:05 PM
klein444
Jun 20, 2015 11:48 PM
TMP025
Chevy/GMC Duramax 01-04 LB7
Feb 16, 2015 12:27 AM
james2562
Feb 5, 2015 09:05 PM
nevadagramm
Oct 17, 2014 07:59 PM
