Trading A Ford For A Dodge.... What To Look For
Old Jul 15, 2008 | 12:08 AM
yep's Avatar
yep
Default Trading A Ford For A Dodge.... What To Look For
Just kind of out of the blue I found a guy who wants to trade his 1994 3500 for my 1997 F-250 7.3L truck.
So knowing very little about Cummings, what should I look for on this truck, which is a 1994 12-valve with 261,xxx miles and a NV4500. Supposedly a newer clutch, batteries, rubber return line and fixed a leaky axle seal on the rear axle, as well as upgraded the starter solenoid.
Other then reading a bunch of stuff about killer dowel pin problem, what else should I be asking or looking for.
Old Jul 15, 2008 | 12:12 AM
DB Admin's Avatar
Banned
First: Welcome To Diesel Bombers !
Second: its not Cummings its Cummins
Third : Sounds like a Good Deal , its the first year of the 2nd Gen trucks it has the smallest P7100 Pump put in a Cummins 160 HP but can be made to make alot more for very low $$$ , other than the KDP not much to worry about
Old Jul 15, 2008 | 12:27 AM
DB Admin's Avatar
Banned
Heres a list i compiled some time ago
this is an excerpt for the 1994 Dodge Cummins Truck Set Backs
KDP, Paint / Primer Failure, 160 Pump, Throttle Cable, Fuel Shutoff Solenoid / Relay Failures, Fuel Lines
These Problems Affect all Years: Steering wander, 5th Gear Nut, TPS, Tranny Cooler Lines and Connectors, Torque Convertor Hunting/Slipping, Fuel Tank Sending Unit Failures, Poor AC Performance, Seat Foam Failure, Console Lid Hinge Failures, Starter Contacts, Axle Lip Seals
Old Jul 15, 2008 | 12:34 AM
94cummins12v's Avatar
dont forget the death wobble
Old Jul 15, 2008 | 09:48 AM
yep's Avatar
yep
Thanks for the info.
Yes typing & spelling after a 20hr shift isn't one of my strong points
Old Jul 27, 2008 | 08:32 PM
Crazylunker's Avatar
Hey you guys forgot the the pulled facial muscles from oversmiling the first time he has to tow with it.
Old Aug 3, 2008 | 02:18 AM
97cummins's Avatar
You can also get a carfax report also to see if it's had any accidents.
Aug 29, 2015 10:10 AM
Greywolf
Feb 17, 2015 06:37 PM
Ryans71
Diesel Engine Conversions
Dec 6, 2014 10:13 PM
Greywolf
Nov 30, 2014 10:57 PM
