General Alt. Question
Old Jul 14, 2008 | 07:34 PM
wildbill's Avatar
Default General Alt. Question
Last week it was up to 100 outside and my alt. was only charging 13.4 volts. Hooked a load tester up and it showed 13.6 so I kicked it in. It dropped but popped back up to 13.6. Why was voltage reading low?
Old Jul 14, 2008 | 08:21 PM
Whit's Avatar
Site Mascot
the voltage is adjusted according to batery temp
there is a sensor under yer drivers side batery that reads the temp
Old Jul 14, 2008 | 08:26 PM
RedRammer's Avatar
Same thing happened to me with the '06 this weekend too. It was doing a full charge when I left home because it was cold out, like 50'F. Stopped for fuel after a couple hours of driving and the voltmeter was left of center (11 volts-ish), I turned everything like lights, heater and radio off. Stopped and restarted truck and no change. I was going camping, pulling the toyhauler, and figured the alternator died and the truck batteries were feeding off the trailer batteries (?). Got to site and tried starting the truck again and it started fine. Last night there I plugged the trailer cord into the truck over night and took a voltage reading of 13.2VDC on the truck batteries in the morning (after sitting for five days) and I know my trailer only charges at 12.5VDC. Started the truck to leave and all was fine again. The belt is new. So.... alternator? voltmeter? quirk?
Old Jul 14, 2008 | 08:36 PM
Whit's Avatar
Site Mascot
these systems are wierd but they work run em and watch em
Old Jul 14, 2008 | 10:35 PM
wildbill's Avatar
Just a bit ago found out that the regulator drops the voltage in hot weather to keep the batteries from over charging. Sound about right?
Old Jul 15, 2008 | 12:19 AM
What he said...
Forks diesel nut
Diesel Engine Conversions
Jul 27, 2015 12:19 PM
torg73
May 11, 2015 03:08 AM
99&91cummins
Mar 4, 2015 01:56 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
