CP3 "Overflow Valve"
Old Jul 14, 2008 | 10:12 AM
Johnny Cetane's Avatar
Default CP3 "Overflow Valve"
Someone told me I needed to upgrade my "overflow valve"?
Does the CP3 have an "overflow valve" or is this person talking about the FPRV?
Old Jul 14, 2008 | 06:19 PM
2500HeavyDuty's Avatar
yes u can do a bottle test to see if u need to shim the fprv.
Jdugie or tracey can provide u with more info on it, i dont have this problem with my motor
thats a lly/lbz thing too
i think lmm also
Last edited by 2500HeavyDuty; Jul 14, 2008 at 06:19 PM. Reason: Automerged Doublepost
Old Jul 14, 2008 | 06:23 PM
jdugie123's Avatar
ya they are most likely talking about the FPRV i just did a race valve some say not to do that but i haven't had any problems and i don't have to worry limping because of a 1093. you could do a shim kit if you haven't blown the valve to much
Old Jul 14, 2008 | 06:30 PM
You use the bottle test to determine if you need shivs or not and how many right?
the race valve just cuts the return fuel line off completely don't it?
Old Jul 15, 2008 | 08:54 AM
jdugie123's Avatar
no the bottle test only works on the LBZ engines the LLY will just thru a 1093 if the problem is not enough fuel but it can be solved three ways get a lift pump, shim the valve or do a race valve like i did
Old Jul 15, 2008 | 06:31 PM
well i got more problems than that, my injection system is 8 years old on a first try CR
i have a few worn parts. works perfect stock. but for the tuning i got it gives me large fuel system leak, i just tune it off with efi untill i get it fixed.
Old Jul 16, 2008 | 12:12 PM
jdugie123's Avatar
you may want to try and get in contact with Oddone he was able to get a lbz CP3 on his LB7 i have the tune we had to use to make it idle right but Guy side every truck may be different
Old Jul 16, 2008 | 12:53 PM
DangerousDuramax's Avatar
Dont forgot that when you install an LBZ CP3 on a non-LBZ you have to change the voltage in your tune to allow the CP3 run and idle properly.
Old Jul 16, 2008 | 03:19 PM
jdugie123's Avatar
ya that is what we had to do
Old Jul 16, 2008 | 06:10 PM
yeah its the opposite, at idle it would be like 23kpsi and WOT itl be like 5kpsi
kinda crazy.
I seen a few lbz cp3's for same for pretty cheap out in the marketplace. U gotta re bend a hard line to get it to fit IIRC
crusty
5.9L CR Performance
Apr 26, 2015 03:31 PM
schwier94
17
Apr 7, 2015 03:16 PM
Cage
Pay It Forward
Mar 27, 2015 12:19 AM
schwier94
Mar 24, 2015 12:18 PM
damanrescue
Chevy/GMC Duramax 01-04 LB7
Dec 2, 2014 04:12 PM
