Diesel Dawgs Performance Visit - Diesel Dawgs Performance
Bully Dog Triple Dog E3 Economy Downloader
Old Jul 13, 2008 | 03:54 PM
FormerVendor
Default Bully Dog Triple Dog E3 Economy Downloader
99-08 Powerstroke
01-08 Duramax
03-08 Cummins
The Triple Dog E3 Diesel downloader is designed to provide added performance and economy. Everything packed into this product, from the engine tuning to the speed limiter function is designed to help users achieve better fuel economy and usable performance gains. This product was also designed to accommodate a lower price point, the price has been significantly reduced from our regular Triple Dog Product line. The Triple Dog E3 carries one engine tune to make things easy for the end user. That one engine tune is adjustable On-The-Fly, so the user can toggle back and forth between that tune and their stock power level, a matter of convenience. The Triple Dog E3 will work on over 20 different vehicle applications including Dodge, Ford, GM diesel pickups and the Ford Excursion.
The engine tuning options below describe the engine tuning available through the Triple Dog E3 diesel
• Stock: Choosing the Stock engine tune will result in no change to engine horsepower output. All other downloader features can still be accessed if the Stock engine tune is chosen.
• Tow/Economy: This tune can be used for everyday driving and towing. Dynamometer testing results have shown a 50 horsepower and 100+ lbs. ft. of torque increase in rear wheel horsepower.
Over 20 different vehicle applications!
Between Dodge, Ford, GM, and Nissan pickups and SUVs the Triple Dog E3 works on over 20 of them. Check out the vehicle application chart to see all of the applications that currently work on the E3.
Speed Limiter
The stock OEM speed limiter will limit the vehicle to a top speed that is determined by the OEM. The vehicle speed limiter feature can be adjusted downward from the OEM position (around 98 mph) to limit vehicle top speeds. The results in field testing show that fuel is saved when top speed is limited.
Calibrate OEM Speedometer
Adding a different sized tire than the stock OEM tire size will cause the speedometer to read incorrect speeds.The Triple Dog E3 Downloader can calibrate the OEM speedometer to read correctly for many different tire sizes. This feature is available on most all of the vehicle applications.
DPF burn-off/ Mobile Desoot
This feature will send a request to the vehicle to move into a regeneration mode to burn off the Diesel Particulate Filter on the late model diesels that have the diesel particulate filter. This feature is only available for GM Duramax LMM and Dodge 6.7L Cummins.
$373.15 Shipped
Old Jul 20, 2008 | 02:21 AM
2500HeavyDuty's Avatar
can it turn off the speed limiter on a 01 dmax?
Old Jul 20, 2008 | 11:38 AM
FormerVendor
Good question..... I will find that out
GenIII04.5
Jun 1, 2015 09:35 PM
alex74708
Dec 18, 2014 07:54 PM
gump
For Sale
Nov 18, 2014 03:55 PM
