Injector Removal And Install E-350 Van 7.3 Diesel
Old Jul 10, 2008 | 02:40 PM
motorcyclemarty's Avatar
Default Injector Removal And Install E-350 Van 7.3 Diesel
Is there enuff room in the engine area to install new injectors or do I have to drop the engine? Thanks in advance - Marty
Old Jul 10, 2008 | 03:57 PM
wildbill's Avatar
You might be able to get by lifting the body off the frame just enough to make room. If not, probably have to drop the engine.
Old Jul 22, 2008 | 03:18 PM
navalseabee's Avatar
i met a guy that has a ford van ambulance that has a 6.9 idi and he pput 7.3 injectors in it with out lifting the body or pulling the motor, well thats what he told me anyways, looked real tight to me.have fun
Old Jul 22, 2008 | 03:25 PM
wildbill's Avatar
Helped a guy do a set of heads on a 7.3 van. He had to lift the body up a ways to make room.
Old Jul 23, 2008 | 08:59 PM
big van's Avatar
You have plenty of room. I've done the IP & injectors on my 87 E-350 4x4. No problem!
Old Jul 23, 2008 | 11:54 PM
Mr. Miyagi's Avatar
IDI engines...no problem.
DI engines...a little tight but can still be done.
Old Oct 19, 2008 | 06:43 AM
wildbill's Avatar
SPAM!!!!!!!!!!!
Old Jan 20, 2009 | 10:56 AM
Jay's Avatar
Jay
Default You dont have to do any of that
We replaced out injector pump and the injectors of our 93 econoline and all you have to do is pop the hood and take the engine cover in the cab off. Our engine was running really rich and washed out a cylinder or two and we replaced the pump and it fixed all of our problems. We did the injectors just because you are supposed to do them both at the same time. Do not drop the engine unless you have nothing else better to do and you like takeing 4x as long as you need to. Good luck PM me if you need any more van advice.
