Got An Annoying Noise Out Of The Motor!
Old Jul 2, 2008 | 07:25 PM
Grim Reaper's Avatar
Default Got An Annoying Noise Out Of The Motor!
ok, after my rebuild, i have an annoying sound coming out of the rear of the motor that i cant figure out.. ill start with saying that we had to hone the 6th cylinder out quite a bit, but i dont think thats the issue cuz i have dang virtually no blowby.. there is the usual smoke coming out of the tube, but no oil. the motor has about 1500 miles on it now. the noise sounds like a dry lifter, like a cack-cack-cack sound.. it is really bad when you first start it up, like theres no oil back there, then it goes away for a brief moment, then comes back, but not as bad as when its started. this is driving me nuts! does anyone have any idea of what it could be?? oh and i do have a street cam in this along with 110lb springs and HD pushrods if that makes any difference.. thanks in advance for the help!
Old Jul 2, 2008 | 07:28 PM
stkdram55's Avatar
make sure you got everything tightened down good something might have loosened up with all the vibrations
Old Jul 2, 2008 | 07:40 PM
any ideas as to what may have come loose? ive tightened pretty much everything outside of the motor, and the stuff on top of the head...
Old Jul 2, 2008 | 09:35 PM
2141pete's Avatar
are your rocker arms worn any or is it louder than that?
Old Jul 2, 2008 | 09:48 PM
stkdram55's Avatar
i would just pull the valve cover and make sure all the jam nuts on your valve adjusters are tight and make sure one of them isnt out of adjustment
Old Jul 2, 2008 | 10:02 PM
ok, i have checked valve clearance, and its ok... you know i didnt think about the rocker arms being worn, cuz thats where it sounds like where its coming from... but when i was assembling the engine they didnt look that bad
Old Jul 2, 2008 | 10:07 PM
stkdram55's Avatar
are you sure its coming from the top of the engine
Old Jul 2, 2008 | 10:08 PM
crazytexan's Avatar
Old Jul 2, 2008 | 10:28 PM
as far as i can tell, yes it is...
Old Jul 2, 2008 | 10:33 PM
Benjamin's Avatar
Bombardier
how much did you hone the cyl. wall on number 6? sounds to me like you have some piston slap.
