EZ Drainplug 94-02
Old Jul 2, 2008 | 03:05 PM
Red_Rattler's Avatar
High Tech Redneck
Default EZ Drainplug 94-02
$25 firm....The EZ Drain Plug helps in several ways. It permanently replaces the drain plug . . . no more leaking plug seals/washers, and the factory plug is replaced, eliminating the opportunity of fracture. But the real benefit of the plug is the way in which it simplifies oil changes. The patented drain tube screws into the oil plug. As you screw in the drain tube assembly, it pushes up a rubber sealed/spring loaded drain valve. Drain the oil, remove the drain tube (thus resealing the drain valve), reinstall the rubber sealed drain cap, and you’re finished.
Would had kept it for sure but it won't work on my 03. Just ordered a new one from genosgarage! Love it, no mess with this plug! All you'd have to buy to make it work is the drain tube that screws on seen here---> EZ CHANGE DRAIN TUBE (ALL YEARS - DODGE)-Dodge Cummins and Ford Power Stroke Diesel Truck Accessories - Geno's Garage Beacuse I'm keepin mine for the new plug, its only 12 bucks...
Old Jul 16, 2008 | 06:49 PM
High Tech Redneck
Bump.....
Old Jul 16, 2008 | 07:39 PM
Ive got one of these...and it sure takes most of the pain (and a lot of the mess) out of changing oil. You can empty your crankcase right into your empty jugs....with this, you dont even need an oil pan.
Old Jul 16, 2008 | 10:59 PM
01quadcab's Avatar
is that shipped?
Old Jul 17, 2008 | 09:59 AM
Old Jul 17, 2008 | 10:31 AM
Wyatt Earp's Avatar
I've got to get me one of them...
Old Jul 17, 2008 | 04:15 PM
High Tech Redneck
not shipped and I have one!
Old Jul 17, 2008 | 11:14 PM
01quadcab's Avatar
price to 96088 I could use one. then gotta order the tube. getting ready to make the change to amsoil in the motor and when the trans is ready that too. it's done wonders in everything so far.
Old Jul 18, 2008 | 03:29 PM
High Tech Redneck
10 bucks to get it to Cali... I have Amsoil in the tranny and axels and I picked up milage... Good stuff
Old Jul 18, 2008 | 04:00 PM
01quadcab's Avatar
I might as well just order a new one and a tube at the same time as 4 bucks over new doesn't seem worth it to me. should be able to ship in an envelope from usps for less
