Thoughts On This Turbo?
Old Jun 29, 2008 | 01:56 PM
CumminsCrazed's Avatar
Default Thoughts On This Turbo?
eBay Motors: CUMMINS PDR HX40 TURBO 94-02 DODGE W/ EXHAUST MANIFOLD (item 230266432833 end time Jul-05-08 18:32:13 PDT)
would that turbo work ok for just my comp box for the time being?
Old Jun 29, 2008 | 03:30 PM
It better go cheap cause you are going to spend a lot of $ shipping that POS OEM manifold.
Old Jun 29, 2008 | 11:42 PM
dukeboy_318's Avatar
the HX40 will work fine for you zach
Old Jun 30, 2008 | 11:54 AM
GetBlown5.9's Avatar
BTW if you didnt know thats a 12v manifold so its junk to you anyway
Old Jun 30, 2008 | 01:35 PM
well i had plans of an ATS 3 pc. if i get it anyway...im not putting a stock manifold back on once mine is off!
Old Jul 2, 2008 | 03:22 PM
Red_Rattler's Avatar
High Tech Redneck
Your gettin the manifold with it because it looks like that darn thing is rusted on!
Old Jul 2, 2008 | 03:42 PM
Wyatt Earp's Avatar
HX40 are slow at spooling up. There are other things I will get into off line if you want.
Old Jul 2, 2008 | 06:25 PM
High Tech Redneck
If it is actually a PDR HX40 it is modded for better spool-up that a reg HX40 that was designed to be run on a 7-11 liter engine. Has to be a PDR version though which this one says it is, but they painted it black so you can't see any of the writing on it.... It should have PDR scribed into it and the compressor side. Is it a 16cm or 18cm cause you going to want the 16 for the faster spool-up. Plus your going to need a new down pipe since the exhaust housing is 4" diameter too... I'd say do your homework on this one b4 you take the plunge. JMO
Old Jul 2, 2008 | 08:26 PM
Wyatt Earp's Avatar
I too can see that and know that it is what it is. It will work but there are better options available to Zach.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
