I NEED HELP
Old Jun 29, 2008 | 01:54 PM
navalseabee's Avatar
Default I NEED HELP
My friend has a 87 6.9 thats got one problem and we can't figure it out. The truck won't start by it self, it has to be pulled, but it only like 10 feet then it fires right up and stays running. And if you stall it out and immediatly try to fire it again it will no problem. So heres what we've done; changed fuel lines, changed fuel filter, new glow plugs, the injectors check out to be good, and so does the lift pump. We have also bled the intire fuel system. It won't even start with ether, and we even tried to like prime it and put raw diesel into the intake manifold and it wouldn't start.
Old Jun 29, 2008 | 02:09 PM
wildbill's Avatar
Remove the return line and check valve on the injector pump. Try and start it then.
Old Jun 29, 2008 | 02:24 PM
the little ball and spring thing right??? won't that leave a chance for it to run away on me??
Old Jun 29, 2008 | 02:39 PM
wildbill's Avatar
Yep! It's there to keep fuel from being siphoned out of the pump when it's sits. It won't run away.
While were at it, remove the wire and check for solenoid action. If it doesn't click real good w/ the check in, but does a bit better w/ out, the solenoid is bad. The return needs to work or the injector pump pressures up and it won't start/run real good.
Old Jun 29, 2008 | 10:35 PM
ok we will have to give it a whirl.....hey man how the heck do you know so much??? its impressive
Old Jun 29, 2008 | 10:39 PM
wildbill's Avatar
Drove too many Oldsmobiles with the 5.7L diesel. They had the same exact company make their inj. pump as Ford did for the 6.9 and 7.3
Old Jun 29, 2008 | 10:54 PM
RTL Garage's Avatar
Very Nice Bill! Thanks For Jumpin' In!
Old Jun 29, 2008 | 10:57 PM
wildbill's Avatar
Old Jun 30, 2008 | 09:23 AM
Old Jun 30, 2008 | 09:40 AM
wildbill's Avatar
So does that mean it's running?
