EGT On The Duramax
Old Jun 27, 2008 | 08:42 AM
Johnny Cetane's Avatar
Default EGT On The Duramax
I'm used to everyone spouting 1250* is the maximum temp for the Cummins so what does everyone say about the Duramax?
Do you stick with 1250* or does it like to run a bit hotter?
Do you go off of what your pyro says or do add a couple hundred degrees to account for the air going through the CAC? (i.e. 1250* is max but you are OK with 1450* at the pyro because the CAC drops it 200*)
Old Jun 27, 2008 | 08:58 AM
Rttoys's Avatar
Most will say 1350-1380 max, others will say lower. Completely stock, mine will run 1320-80 pulling uphill around here.
New numbers soon to come...
Old Jun 27, 2008 | 09:05 AM
This should be interesting.
I've also heard that you have to be careful with rapid heating/cooling cycles on the Duramax because of the aluminum heads. If you spike your EGTs then let them drop rapidly you can blow a HG. Anyone know if there is truth to this?
Old Jun 27, 2008 | 10:29 AM
2500HeavyDuty's Avatar
There is no hills around "here"
I just got done towing The camper trailer out in the hilly part of texas, egts only got to about 1400 twice only cause i wanted to see the truck kill mosquitoes
With Stock intake 5 inch exhaust and my race EFI tune
Old Jun 27, 2008 | 02:55 PM
redneckbuckeye's Avatar
1400 is a number I have heard a lot
Old Jun 27, 2008 | 04:07 PM
Oilfield_Mafia's Avatar
I just pulled my 5ver from Poteau, OK to Erick, OK around 450 miles the way i went.. and the last 175 miles were into a very strong head wind .. (typical western Oklahoma) and my EGT's stayed right around 1300.. I was told 1250 about 2 weeks ago when i got these gauges, but I just cant see that being all I should run.. I mean even when I put the bully dog on stock tune it runs up to 1450 or 1500.. When I pulled the camper out here on this trip I was using the Tow tune on my bully dog.. Camper and truck together weighs about 300 pounds shy of 20,000. Im kinda thinkin about getting a 1 - ton next time for the lower gears..
Old Jun 27, 2008 | 07:42 PM
slowtowpig's Avatar
i spike at 1400, but thats a ford. i would think in general you wouldnt want to get over 1400, i cooked my last one at 1600.
Old Jun 27, 2008 | 07:56 PM
i did one run on the free way with the boat hitting 1600+
Hey all dmaxes come with 3.73 stock
Old Jun 27, 2008 | 08:02 PM
what? are you sure? I thought You could order the 3500's with 4.10 gears?
Old Jun 27, 2008 | 08:07 PM
you should be able to order it with 4.10
