What Is This???
Old Jun 26, 2008 | 07:01 PM
Red_Rattler's Avatar
High Tech Redneck
Exclamation What Is This???
Curious as to what this is? Im guessing its for rail pressure some how some way and how will this allow up to 65hp by allowing the rail pressure to read more psi? Fill me in....eBay Motors: 03-07 Dodge Ram Cummins 5.9L CP3 Chip Tuner Programmer (item 160254809210 end time Jul-05-08 09:22:11 PDT)
Old Jun 27, 2008 | 09:44 AM
staarma's Avatar
It's just a rail pressure sensor with a different calibration. It basically lies to the ECU and says the rail pressure is lower so the ECU will command more pressure. If the commanded pressure from the ECU is say 23000 PSI then the "calibrated" sensor from SP would report the actual rail pressure at 21000 PSI then the ECU will command 2k more thus resulting in an increase of HP/TQ.
Old Jun 30, 2008 | 01:05 AM
CTD03's Avatar
its not even worth the money
just cap your rail .02
Old Jun 30, 2008 | 04:30 PM
2500HeavyDuty's Avatar
more rail pressure means better atomization for a better burn
Old Jun 30, 2008 | 04:57 PM
mikmaze's Avatar
don't forget to add faster wearing injectors too..........
Old Jun 30, 2008 | 05:04 PM
and wearing of the pistons
Old Jun 30, 2008 | 05:42 PM
High Tech Redneck
Ha whoa.... How many miles were on that motor?! One thing always leads to another
Old Jun 30, 2008 | 05:49 PM
miles i dont know, its a daily driven 10 second truck.
But hes running dual modded cp3's and maxed out rail pressure. also turning out 4500+rpms
Old Jul 1, 2008 | 11:08 AM
twoforme2's Avatar
cool, I dont remember seeing pistons with the optional Flower pattern molded into the top.
Looks expensive!
Old Jul 1, 2008 | 05:05 PM
theyre lighter than stock
