What Transmission?
Old Jun 25, 2008 | 07:52 AM
West Electric's Avatar
Question What Transmission?
help,
2002 dodge CTD 3500,2wd cab/chassis i have the 5 speed transmission and cant find the drain plug..
do i have to take off one of the PTO side plates to drain?
also what is this transmission called? NV-what...4500?
is this it?
http://www.drivetrain.com/newventure.html
I need to chainge the oil in it.. is Pennzoil syncromesh ok?
Old Jun 25, 2008 | 09:41 AM
Yes, you have a NV-4500 (probably the HD version):
Ram NV4500 Specifications
And you change the fluid by removing the bottom bolts on the PTO plate (or whatever you want to call it). Remove the covers and clean the crap off the magnet as well reseal with a little RTV sealant.
You only want to use Castrol Syntorque (NOT Castrol Syntech) and it takes 8.5 pints.
These are the ONLY lubricants recommended for the NV4500:
75W-90 Castrol Syntorque Synthetic
Mopar Manual Transmission Lubricant (PN 4637579)
GM Transmission oil (PN 12346191)
NOTE: Syntorque is NOT the same as Castrol Syntech.
Using different lubes in the NV4500HD will damage the carbon fiber synchros. You can get away with different lubes in the 6 speed because it has brass/bronze synchros but not with the 5 speed. Many people learn this lesson the hard (and expensive) way.
BTW, welcome.
Old Jun 25, 2008 | 10:20 AM
Thanks for the info Dr. E... guess im off to the parts counter..
Old Jun 25, 2008 | 11:47 AM
Take your credit card....
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
SixSpeed
Jan 11, 2015 01:41 AM
W350-4x4
Nov 12, 2014 09:35 AM
TheDirtyDozen
Oct 1, 2014 10:09 AM
