Loosing Coolant At The Reservoir
Old Jun 22, 2008 | 09:58 PM
I know my 6 litre sucks's Avatar
Default Loosing Coolant At The Reservoir
I have a 2005 6 litre and it blows hot coolant out at the resivoir. Just wondering what my problem is?
Old Jun 22, 2008 | 10:10 PM
wildbill's Avatar
How hard does it blow out? If it's ginning, cracked/warped head or leaking head gasket.
Old Jun 22, 2008 | 10:25 PM
only blows out when under load. like towing a trailer or with the programmer turned up and with my foot in it. not alot and only if it is hot outside.
Old Jun 22, 2008 | 10:35 PM
wildbill's Avatar
AC turned on? Partially blocked radiator, sticky thermostat, programmer may have something to do with it. DB has a few Ford gurus, and they can go a little more into the programmer end of things.
By the way, welcome to DB!
Old Jun 22, 2008 | 10:37 PM
YMMOT's Avatar
Could be a couple things.
What progammer?
I'm gonna say it's time for studs most likely though by your statement of it does it under load.
Old Jun 22, 2008 | 10:44 PM
did it with both Banks 6 gun and Predator downloader
does it with both Banks 6 gun and Predator sport downloader
Last edited by I know my 6 litre sucks; Jun 22, 2008 at 10:44 PM. Reason: Automerged Doublepost
Old Jun 22, 2008 | 10:46 PM
wildbill's Avatar
Might be too late to try w/ out either hooked up. Worth a shot!
Old Jun 22, 2008 | 11:24 PM
Predator has been know to blow head gaskets on the 6.0's. How long has it been doing this?
Old Jun 23, 2008 | 12:36 AM
YMMOT's Avatar
My money is squarely on headgasgets. The other option would be a cracked EGR Cooler, but that USUALLY will leave a small puddle of coolant behind the passenger side front wheel.
Old Jun 23, 2008 | 12:46 AM
My 04 F-250 would blow some coolant when I first got it because it was overfilled with cooltant from the factory.
