12 Valve Shuttering
Old Jun 22, 2008 | 05:50 PM
Stone007's Avatar
Default 12 Valve Shuttering
I am new to the cummins but have had a lot of stroker fixes.
I have a 96 cummins and the original turbo failed. So of course I replaced it with a bigger one, an aurora 3000. I also replaced the injectors with 270's, removed the air box and installed a stage 2 afe. The exhaust was already 4" from the previous owner. The truck has 190000 on it. When I started it the engine runs smooth at idle but if you give it fuel the engine shutters and pukes black and then white smoke. Through these forums I learned about the fuel plate and ground it to a #10, slid it 1/16" back from full forward and slid the cover all the way forward. Didn't make much difference with the shuttering and smoke issues, infact may have made it a little worse. If you hold the throttle it one position everything clears up, but if you give it more the engine shutters again and blows the black followed by the white smoke.
Timing maybe?
Old Jun 22, 2008 | 05:53 PM
Benjamin's Avatar
Bombardier
i'm thinking fuel supply. i'm hoping too that you are letting the truck warm up to operating temp before reving it. my 96 wants to pop and studder if it isn't at operating temp.
when was the last time the fuel filter was changed?
could be that, the overflow valve or the lift pump dying.....
Old Jun 22, 2008 | 05:54 PM
Benjamin's Avatar
Bombardier
also at what rpm is it doing this? 1500? 2000? 3000?
Old Jun 22, 2008 | 06:39 PM
stkdram55's Avatar
did you mess with the timing? yeah i would check your filters and check your fuel pressure if the filter change doesnt clear it up
Old Jun 23, 2008 | 11:56 PM
Stone007's Avatar
I'm not sure on the fuel filter but I will change it next.
When I take the truck out it doesn't seem to do the strange shuttering and white smoke bit. Just a lot of black for the first part of acceleration but clears up with boost. Seems to only do it in park with no load.
Yes the truck still does it after good and warm, and no I didn't touch the timing.
On another note with all the up grades to the stock engine, HOLY CRAP!!! I am very impressed with the way the truck runs. Used to take about 15 mins to accel at 60 mph to 70, now I press the pedal and it lays you back in the seat and the speedo climbs very rapid...I think I pooped my pants a little.
Old Jun 24, 2008 | 12:02 AM
Johnny Cetane's Avatar
I would guess timing slipped a bit maybe??
Don't forget to clean out that pesky pre-filter that is part of the fuel heater. i cleaned mine with every fuel filter change. That screen can cause some odd fueling issues.
Fuel Pre-Filter Cleaning on Ram/Cummins
RA113024
Mar 13, 2016 07:42 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
behrendt1061
Dec 4, 2014 05:49 PM
woodsman27
Oct 26, 2014 02:13 AM
