Auto Or Stick
Old Jun 20, 2008 | 03:58 PM
cumminsboy92's Avatar
Default Auto Or Stick
i recently picked up a 1991 dodge 250 4x4 with a bad auto tranny. i was wondering if i should just replace the stock tranny or switch it to stick. any input
Old Jun 20, 2008 | 04:23 PM
wildbill's Avatar
Depends on what your preferences are. By that I mean, do a significant amount of towing or is it just a daily driver. Switching from one to the other isn't difficult, just takes a little time.
Old Jun 20, 2008 | 07:36 PM
it would be doing some towing and hauling as well as being my daily driver
Old Jun 20, 2008 | 07:41 PM
AF1CUMMINS's Avatar
I know it may be apples and oranges but I did it on my '83 F-150 and it involved a lot. New steering column, transfer case, which meant different drive shafts, pedal assembly, slave cylinder. Lotta work man, might be easier and cheaper to just fix it and trade for a manual if that's what you really want.
Old Jun 21, 2008 | 08:34 AM
as for 1st gens i would go stick. just not enough upgrades to make those older autos hold up if your gonna add more power or tow anything.
Old Jun 21, 2008 | 09:18 AM
Diesel Nut's Avatar
Big problem with the 1st gen autos is they do not have a lock up converter. If you found a smokin deal on a 47rh you can mount that up with minimal trouble, have a more durable transmission with a lock up converter.
How heavy will you be towing?
Old Jun 24, 2008 | 12:03 AM
smoke' em's Avatar
go with a nv4500 you'll never look back
Old Jun 24, 2008 | 12:04 AM
2500HeavyDuty's Avatar
STIIIIICK!
Old Jun 24, 2008 | 12:11 AM
Johnny Cetane's Avatar
If you're going to keep it and work it I'd get a stick. As said above a NV4500 would be a great one to put in. You'll need to do something with lengthening/shortening driveshafts, mating the t-case up, cross members, shifter, etc. It will be a lot of work and I would bet you'll get $3500-$4000 wrapped up into it pretty quick unless you could find everything at the junk yard.
Old Jun 24, 2008 | 12:52 AM
Uncle Bubba's Avatar
There's plenty of kits out there to do this with. Most of them I have seen are complete with all the parts. The only thing left for you to do is get your drive shafts lengthened and shortened. Most any machine shop can do this for you but you have to wait till you have it all installed so you have your exact measurements.
