New DTC?
Old Jun 20, 2008 | 11:09 AM
Oilfield_Mafia's Avatar
Default New DTC?
I just went to leave the house and got a P0700 and it didnt wanna come out of 4th gear...
Checked the code and its
p0700 - TCM requested MIL Illumination..
p0700 - TCM Malfunction
Any Ideas? Did I tear Something up or what?
Thanks,
KC
Old Jun 22, 2008 | 01:58 PM
DB Admin's Avatar
Banned
The ECM illuminates the Check Engine Light when the diagnostic of the Allison runs and fails.
Conditions for Clearing the DTC
  • The ECM turns OFF the MIL after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
  • A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
  • A scan tool can clear the code from TCM history. The TCM automatically clears the DTC from TCM history if the vehicle completes 40 warm-up cycles without failure.
Sounds like a Companion Code
Old Jun 23, 2008 | 05:50 PM
2500HeavyDuty's Avatar
Thanks,
KC
You limped it, welcome to the club
Just reset the taps and turn the power down a little or just ease into 5th gear now, every time you limp it you burn a little bit more of the clutch and its holding power goes down and after a few dozen limps you will need a rebuild badly
Dbleo351
Nov 20, 2016 09:34 AM
JJ Diesel
Mar 20, 2016 07:39 PM
boneheaddoctor
Jan 15, 2016 06:19 PM
ctjkelley
Jun 3, 2015 06:01 AM
daniel2500
Apr 27, 2015 06:04 AM
