A/C Shaft Seal
Old Jun 20, 2008 | 03:36 AM
GlennO's Avatar
Default A/C Shaft Seal
Is this an easy fix, or is it a dealer fix item???
Old Jun 20, 2008 | 11:33 AM
Uncle Bubba's Avatar
Hey Glenn little band O brothers here. I've hunted through Alldata cause I wasn't sure what you were talkin about here and still came up empty. Can you give us some more info on what your doin and what the problem is.
Old Jun 21, 2008 | 09:53 AM
GlennO's Avatar
Oh sorry about that.
I am talking about the air condotioner compressor shaft seal.
Its leaks freon and won't cool, I put some of that stop leak freon in but didn't help.
Is it easyer or cheaper to replace the compressor or fix it?????
Thanks
Old Jun 21, 2008 | 10:43 AM
wildbill's Avatar
If you have access to a junk yard, I'd get a replacement.
Old Jun 21, 2008 | 10:46 AM
Whit's Avatar
Site Mascot
prolly the reson the seal is gone is because the bearings are gone too.....JMO
go get one from the junk yard ....cheap deal right there
Old Jun 21, 2008 | 10:48 AM
wildbill's Avatar
Which reminds me. If you do go that route, make sure it has new oil in the compressor.<<<<Friendly reminder!
Old Jun 21, 2008 | 01:09 PM
RTL Garage's Avatar
If The Clutch Assembly Is Not Pulled Properly You'll Destroy The Compressor Worse That What You Started With.
But, If Your Feeling Daring - There Is Rebuild Kits Available To Rebuild Most Compressors. Your Better Off Doing A Bench Rebuild - Just Remember To Vaccum Down The System And It Never Hurts To Replace The Drier When You Remove The Refrigerant In The System. R134a Self Contains The Lubricant But There Is Specific Parts To Lube On The Compressors Moving Parts
http://www.jcwhitney.com/SPECTRA-PRE...2282_10101.jcw
Hope That Helps
morris360
Aug 5, 2015 09:25 AM
Maclain Marsh
Jul 13, 2015 06:23 PM
Jladanyi
Jul 4, 2015 02:43 PM
CumminsCoalRoller24/7
May 5, 2015 08:55 PM
JasonG.
Ford Powerstroke 08-10 6.4L
Feb 26, 2015 08:51 PM
