Idle Problem
Old Jun 19, 2008 | 08:50 AM
wallygolf's Avatar
Default Idle Problem
97 cummins with Banks installed. Always ran great until setting for 6 weeks. Now it starts fine but when you stop giving it fuel it will not idle back down. It will stay about 1200 rpms. If you tap the accelerator quickly or restart the engine it will idle fine. The truck runs fine other wise.
Old Jun 24, 2008 | 09:03 AM
MnTom's Avatar
You need to check your linkage for binding. Either that or your IP is beginning to fail you. Meaning a plunger might be sticking.
Old Jun 24, 2008 | 09:14 AM
I believe there was a TSB for throttle linkage replacement:
http://dodgeram.info/tsb/1997/18-29-97.htm
But the problem does sound a bit more like pump issues.
Old Jun 24, 2008 | 10:48 PM
gone ropin's Avatar
check the linkage rod up on the pump for slack, the rod has poly bushings and can be replaced for about 5 bucks from the cummins house,
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
xbreaselx814
Dec 7, 2014 06:59 AM
hunt4beer
Nov 15, 2014 09:06 AM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
