Will 37s Fit?
Old Jun 15, 2008 | 08:58 PM
Monster Truck's Avatar
Default Will 37s Fit?
Will 37-14.50-16'' toyo mts fit under my truck? Im ok with some rub but I dont want it to be stupid. Ive got quite a bit of offset already and Im clearing 35s with no problem.
Old Jun 15, 2008 | 09:02 PM
2500HeavyDuty's Avatar
i think bigblue12 has 39.5 inch iroks on his truck with 5 inches of lift. he did some trimming though
Old Jun 15, 2008 | 09:47 PM
slowtowpig's Avatar
to much of an offset will cause a tire to rub also, but i thank you will be fine tho
Old Jun 17, 2008 | 02:19 AM
Cumminscowboy_101's Avatar
I would just like the opportunity to say...I have no idea.
Old Jul 2, 2008 | 01:51 PM
nmlakerat's Avatar
37's will fit with 5 inches of lift and fender cutouts or fiberglass fenders for baja trucks. unless you run a factory backspace wheel and you get them under it. truck in avatar has 3 inch lift and fenders factory backspace wheel and 37's but its an 03
Old Jul 2, 2008 | 06:31 PM
MotorOilMcCall's Avatar
They'll be close. You'll definitely rub at full lock, but hopefully just on the fender liners, it depends on what backspacing. You may need to trim the front bumper a little, and the back part of your wheel well. One other thing I noticed in your sig, no mention of an upgraded track bar. With 37's, your gonna wanna give Don Thuren a call and have him fab you up a new one, otherwise your gonna toast the one that came with your lift in a hurry. Might wanna look into a set of 4.10's to replace the 3.54's you have, it'll give your ride a little more pep off the line.
Old Jul 2, 2008 | 09:28 PM
sidekick's Avatar
I have 37x 12.50 with 6" and lots of clearance if needed stack a leveling kit on the lift spirngs
Old Jul 23, 2008 | 11:49 AM
nmlakerat's Avatar
I personally do Not recomend stacking a leveling kit under lifted springs.
landon025
Sep 8, 2015 09:21 PM
Jsully
Aug 31, 2015 07:55 PM
CumminsAtYa
Apr 23, 2015 04:20 PM
carmel
Mar 20, 2015 09:25 PM
Supremedragonx
Mar 1, 2015 01:50 PM
