2003 Ram 3500
Old May 9, 2018 | 02:44 PM
jstoshick's Avatar
Default 2003 Ram 3500
2003 Dodge Cummins 5.9L Diesel 3500 4x4 Dually
Less than 5K miles on recent professionally rebuilt automatic transmission. "Bulletproofed Build" - check out https://goerend.com/dodge/ -- and research reviews -- suggest combo of parts is a 800+ hp capable transmission. Goerend parts; deep pan, triple disc torque converter, billet shaft, billet 3.8 lever strap + anchor, & high pressure valve body w/ GM solenoid. Have documentation / professional shop w/ good reputation rebuilt.
Block heater, Load E BFG - tread remaining but with a little checking in the side walls.
High-Output model. 5" exhaust all the way back (6" stinger pipe) and K&N air filter.
4.10 gears. Gooseneck ball. Receiver hitch.
Newer ARE camper with carpet, side opening windows and locks w/ keys, camper was $2,700 new. Heavy duty bed-liner.
Clean inside and out, straight body with only a few dings in the bed/tailgate, trivial interior etc wear & tear. Significant maintenance history. Recent clean CarFax / clean title. Car spent a majority of its life in the southwest and CA - underside is also very clean.
140k miles. $13,580 firm. Would pick up from airport if needed - can stay at log cabin & see NW Montana if you like for a few days.
Attached Thumbnails 2003 Ram 3500-20180429_085632.jpg   2003 Ram 3500-20180429_085643.jpg   2003 Ram 3500-20180429_085700.jpg   2003 Ram 3500-20180429_085728.jpg   2003 Ram 3500-20180429_085615.jpg
