Diesel Related Events Post All Diesel Related Event Information, Dates and Results Here - Includes Racing, Pulling, Dyno ect... All Local, State and National Event Information
*POST AND DISCUSS ALL DIESEL RELATED EVENTS HERE*
Raymond, IL Sled Pull July 5th
Old Jun 11, 2008 | 09:50 AM
BlinkGraphics's Avatar
Default Raymond, IL Sled Pull July 5th
4 X 4 STREET TRUCK PULL
Saturday, July 5th @ 11:00 a.m.
Raymond, IL
1 Block south of route 48, off Main Street, across from new firehouse
Registration Starts at 9:00 a.m.
$20.00 per Hook
Will have portable scales at track
Classes:
Factory Gas 4x4- 6,000 and 6,500 lbs.
Modified Gas 4x4- 6,000 and 6,500 lbs.
Street Diesel- 8,000 lbs.
Open Diesel- 8,000 lbs.
Gas/Diesel Challenge- 7,500 lbs.
There will also be concessions on site
Street Truck Pull Rules and Regulations
Judges and Track Officials reserve the final word on classification, equipment, and safety
General Rules:
1. All Drivers must have a valid driver’s license. No riders allowed.
2. Trucks may pull in a higher #class, gas to gas, diesel to diesel, but not lower a class.
3. Must have valid registration, and in safe operating condition.
4. Motor must have been from the factory in a 1 ton or smaller truck and must remain in factory location.
5. Each truck must be equipped with a minimum 3” clevis, inside diameter opening for the sled hook and must be provided by the driver.
6. Clevis is to be no more than 26 inches from the ground, hooking point will be measured to the center of the clevis loop.
7. OEM frame is mandatory.
Classes:
1. Factory Gas 4x4 6,000 lbs and 6,500 lbs- Must retain stock suspension, lift kits are acceptable. Single or dual wheels. Motor must be the same make as truck: Limited modifications to motor, no blowers or turbochargers. Factory type transmission and transfer cases only. Dual rear wheels acceptable, but must have been original equipment. Added weight, traction bars, and blocked rear ends are allowed. ALL TRUCKS HAVE TO HAVE CHAIN OR CABLE LOOPS AROUND FRONT AND REAR DRIVE SHAFTS.
2. Modified Gas 4x4 6,000 lbs and 6,500 lbs- Designed for trucks that don’t comply with the previous Gas classes. Major motor or suspension modifications are acceptable. Hanging weights are allowed to weight vehicle up. Weights must be secured and not extend more than 60” from the front of the center of the front axle. Weights may be securely fastened in the bed of the truck or out front. Aftermarket transmissions and transfer cases are allowed.
Street Diesel 4x4 8,000 lbs- Designed for daily driven stock appearing street trucks. Dual rear wheels permitted. Engine limited to stock appearing make specific compression ignition (diesel). The engine must be governed to a maximum 4500 RPM unless the OEM governed speed is higher. #1 and #2 Diesel Fuel or soy/biodiesel only. Fuel injection pump is limited to stock appearing OEM engine model specific only. The use of multiple high pressure common rail fuel pumps is prohibited. Limited to 1 stock appearing OEM make specific turbocharger only, unless otherwise OEM equipped. Turbochargers from different years within the same make may be interchanged. No nitrous oxide, propane injection, or water injection allowed. If so, components must be removed from the truck. Engine or component changes will be limited to computer chips, programmers, air intake and filtration, and exhaust. OEM fuel tanks must be present and in use. Weight brackets, traction bars, and blocked rear ends allowed. Weights must be secured and not extend more than 60” from the front of the center of the front axle.
0pen Diesel 4x4 8,000 lbs- Designed for daily driven modified streetable trucks. Dual rear wheels permitted. Engine limited to stock appearing make specific compression ignition (diesel). Aftermarket injectors, turbochargers, fuel systems, and dual high pressure common rail fuel pumps or HPOP are permitted. Water (only) injection is allowed, no alcohol, methanol, propane, or nitrous is allowed. Rear suspension must maintain at least 1 inch travel. OEM fuel tanks must be present and used Weights must be secured and not extend more than 60” from the front of the center of the front axle. Weights may be securely fastened in the bed of the truck or out front.
Gas/Diesel Challenge 4x4 7,500 lbs- Rules are same as above
any more questions please contact Ryan Brown at 217-827-2216
duramaxtuner
Show And Tell
Dec 10, 2014 01:45 PM
