HELP
Old Dec 27, 2017 | 07:08 PM
diesel life's Avatar
Default HELP
so this morning it was 0 outside went out truck fired right up got out and it died wouldnt restart. So i went and got some diesel 911 and a new fuel filter put it in and still no start the lift pump is running i also put 911 in the fuel filter housing and nothing. Anybody have any ideas???? Thanks in advance
Old Dec 27, 2017 | 08:45 PM
Bryce's Avatar
Did you bleed the injectors? Last time mine gelled up I had a heck of a time getting fuel flow to the injectors.
Old Dec 28, 2017 | 08:33 AM
I have not i will try that thank you
Old Dec 28, 2017 | 03:31 PM
BentWrench's Avatar
24v’s are self priming. Before cracking lines get the old ladies hair dryer and warm the lines and pump up a bit.
Old Dec 28, 2017 | 05:48 PM
Bryce's Avatar
24v vp44 trucks (98.5-02) are not self priming. 03 up common rail trucks are.
Old Dec 29, 2017 | 01:36 AM
I got er going today fellas, ended up putting the salamander under it for a bit, was gonna crack the lines but as i was looking at the vp there is a port for a test guage, so i bumped the starter 3 times and bled the air out of the system there put the cap back on and bumped the starter 2 more times and the ole gal fired right up.... thanks for the help fellas
