03 DODGE RAM P0483 AFTER NEW FAN INSTALL
Old Jul 2, 2017 | 02:07 PM
scbdispatch's Avatar
Default 03 DODGE RAM P0483 AFTER NEW FAN INSTALL
Fan clutch went out on my 03 Dodge Ram 3500 5.9. When it went out it tore both plugs, truck side & fan side, I had to hard wire the new fan. Afer installing the new fan, I am still showing a P0483 code. Does this mean my fan isn't engaging? Unfortunately my truck never runs over 200 degrees so I don't hear fan kick in and I am not sure at what temp it is supposed to kick in. Any help or thoughts would be greatly appreciated
Old Jul 2, 2017 | 06:35 PM
CumminsCoalRoller24/7's Avatar
Your fan may be working intermittently and not completely dead. I ran with that code for a while before replacing. You definitely will hear it kick on, more so when towing or running AC. Check your connection on lower right of radiator when looking from the outside. Could be a bad connection/cut wire. They aren't cheap for a new one!
