06 engine in 05 truck
Old May 9, 2017 | 08:11 AM
Billyjoeo's Avatar
Default 06 engine in 05 truck
I have installed an 06 engine in my 05 3500 dodge dually and my fuel mileage has dropped to appx 10 mpg when towing. Before I could get 18 loaded. Do I have to get the computer reprogrammed? What else could be going on?
Old May 9, 2017 | 10:31 AM
CumminsCoalRoller24/7's Avatar
Any CEL lights or soft codes? Hand calculated mpg?
Old May 9, 2017 | 10:55 AM
Billyjoeo's Avatar
Default No lights
Yes computer says 11.7 but by hand it's closer to 10. No lights are on
Old May 9, 2017 | 11:27 AM
Billyjoeo's Avatar
Default No lights
Old May 9, 2017 | 07:31 PM
11B/11C's Avatar
Are you using the 06 or 05 ECU?
Old May 9, 2017 | 08:16 PM
Billyjoeo's Avatar
Default 05
The 05 computer
Old May 9, 2017 | 09:17 PM
11B/11C's Avatar
That might be your issue right there.
Old May 9, 2017 | 09:33 PM
Billyjoeo's Avatar
might be or is does anyone know for sure?
Old May 9, 2017 | 10:07 PM
That's your issue, found answer below in a cumminsforum thread...in a nutshell
The 2005 ecm runs the truck using the SCI interface, while 2006 up uses a MUCH more complicated CAN bus system.
carcomputersystem posted on here on 4.18- send them a PM and get an 06 computer. The best thing is you can get EFI tuning with your 06 ecm so you can increase your mileage over your stock 05 #s!
Old May 9, 2017 | 11:05 PM
11B/11C's Avatar
I was pretty sure it was your issue, but wasn't positive. Likes like he found your answer.
