Excessive smoke
Old Dec 6, 2016 | 04:58 PM
Swamper253's Avatar
Default Excessive smoke
I have a 2005 I rebuilt the motor 30,000 miles ago... all stock. The last couple weeks I'm getting a lot of white smoke when I start it up in the morning after its warm no smoke at all......any suggestions?
Old Dec 6, 2016 | 05:12 PM
11B/11C's Avatar
Possibly a leaky injector. I would send an oil sample in and get an analysis done. Is there any blow by?
Old Dec 6, 2016 | 05:19 PM
Swamper253's Avatar
I replaced the injectors about 5000 miles ago... blow by not sure smells like diesel
Old Dec 6, 2016 | 05:42 PM
11B/11C's Avatar
Remanned or brand new injectors? Either way i would get an oil analysis done. I think its only $28 at Blackstone.
Old Dec 6, 2016 | 07:52 PM
Swamper253's Avatar
They are new injectors
Old Dec 6, 2016 | 09:14 PM
11B/11C's Avatar
Retorque your feed tubes and injectors. Run a good dose of injector cleaner through the system encase some gunk is causing an injector to leak.
11B/11C's Avatar
Also make sure you check for blow by.
Old Dec 8, 2016 | 08:26 AM
dangerous1965's Avatar
That is a sure sign of a bad injector get it fixed before you melt a piston! Worst case is you already melted a piston but since the smoke goes away you might get lucky! Pull them all send them back to who sold them to you for testing! really weird that NEW injectors are doing this?! Remans do it all the time!
Old Dec 8, 2016 | 09:16 AM
Swamper253's Avatar
That's what I was afraid of....I appreciate the input.
