47re to NV4500 swap questions
Old Dec 4, 2016 | 07:14 PM
Texas24Valve's Avatar
Default 47re to NV4500 swap questions
Tired of my 47re so I picked up a 2wd NV4500 from a parts truck. I know im gonna need a 29 spline for the 241dhd transfer case, 4x4 mainshaft and 4x4 tail housing. 3rd gear synchro is bad too but I was gonna replace all those anyways and looking at a valair clutch kit. i know I need the pedal assembly and im just gonna throw a shift boot over the whole thing cause it doesn't need to look "factory" to me but besides everything listed what else will I need for the swap and does anyone know where I can find a good write up with pictures? there's good write ups out there but one with pictures would really help. Thanks in advance.
Old Dec 7, 2016 | 03:12 PM
RedChevy44's Avatar
You will need flywheel bolts, clutch safety switch (if desired), transmission exhaust mount plate (the rubber trans mount bolts to it), and you will need to lengthen/shorten your drivelines
