Fuel Pressure Gauge Reading
Old Oct 17, 2016 | 02:31 PM
sucker2's Avatar
Default Fuel Pressure Gauge Reading
Installed VP44 pump and fuel pressure gauge...I have a 7 and almost 8 reading at idle...don't know if my in-tank Carter factory pump 167,000 miles on it is set for higher than that or not...seems like it ought to be so not sure if the FP is weak or not...I'm not sure what it will drop to under load (I pull a 35 ft. 5'er) but I understand anything below 5 is absolutely dangerous to the VP pump and the engine should be shut down immediately to save the VP pump...seems like I'm too close to a reading of 5 to feel comfortable...what say you?...TX.
Old Oct 17, 2016 | 03:28 PM
mpcampers's Avatar
don't know where you got 5 was told 10 no lower...
Old Oct 17, 2016 | 03:46 PM
sucker2's Avatar
Here is an article that will diagnose that for you...hope it helps.
https://www.bluechipdiesel.com/lift_...agnostics.html
Old Oct 18, 2016 | 04:15 AM
gh0stman's Avatar
I wouldn't run it with that pressure. That's just flirting with danger. What is your pressure at WOT?
Old Oct 18, 2016 | 12:20 PM
sucker2's Avatar
Tx. gh0stman...Just tested it at WOT and it fell to 1 pretty fast so I let off right away and it went back up. to 6...kinda scary on a brand new injection pump...the pump has to be weak don't you think?...proof I expect a new lift pump is needed...here is what I got from the mfg. of carter pumps.
The fuel transfer pump (fuel lift pump) is located on the leftrear
side of the engine cylinder block above the starter
motor (Fig. 50). The 12volt
electric vanetype
pump is operated and controlled by the Engine Control Module (ECM) (Fig.
51).
The purpose of the fuel transfer pump is to supply (transfer) a lowpressure
fuel source: from the fuel tank, through the
fuel filter/water separator and to the fuel injection pump. Here, the lowpressure
is raised to a highpressure
by the fuel
injection pump for operation of the highpressure
fuel injectors. Check valves within the pump, control direction of fuel
flow and prevent fuel bleedback
during engine shut down.
Normal current flow to the pump is 12 amperes.
With the engine running, the pump has 2 modes of operation: Mode 1: 100 percent dutycycle
with a minimum
pressure of 10 psi except when the engine is cranking. Mode 2:25 percent dutycycle
with minimum pressure of 7 psi
with the engine cranking
The 25 percent dutycycle
is used to limit injection pump inlet pressure until the engine is running.
The transfer pump is selfpriming:
When the key is first turned ON (without cranking engine), the pump will operate for
Old Oct 18, 2016 | 12:22 PM
gh0stman's Avatar
I would be looking into getting a aftermarket pump. Just driving it around you risk burning up the VP.
Old Oct 18, 2016 | 02:25 PM
sucker2's Avatar
TX. gh0stman...I will do it...you have been a big help to me and I want you to know I appreciate it.
Old Oct 18, 2016 | 03:24 PM
Btp 2332's Avatar
Look at a carter pump from Summit racing, under 100 bucks. Have one on a 12valve no issues holding pressure I just got one for my 24v. I also have a raptor on it shows around 15-19 idle, 9-10 when leaning on it and the tst on 5
Old Oct 18, 2016 | 04:22 PM
sucker2's Avatar
I have the in tank conversion lift pump so it will be a lot more money...sure would be cheaper to bolt onto the frame though but can't do it without spending a lot of money for the conversion kit etc...TX. for the reply.
Old Oct 18, 2016 | 05:12 PM
Btp 2332's Avatar
Cut the line, bolt the pump to the frame, line to the pump done. Couple extra bucks big line kit from Glacier
