Fuel plate and timing
Old Oct 12, 2016 | 11:37 AM
cloker12's Avatar
Default Fuel plate and timing
Had a #11 fuel plate and timing bumped up to 16btc.
Love the power increase but towed with it the first time and was pulling a long grade and looked at the egt Guage and was running in the red....dropped a gear and it went back into the green again but I was kind of disappointed with the fact I had the power button just to much egt.
Any thoughts on where I should go from here
Old Oct 17, 2016 | 06:39 PM
94 12valve's Avatar
if your still running the stock charger adding a boost elbow and cross drilling the wastegate are two cheap things that will help a good deal with your issue.
Old May 16, 2017 | 04:16 PM
cloker12's Avatar
Default cross drilling waste gate?
probably been talked about a bunch but would you mind going into how you go about cross drilling the waste gate a little bit
Thanks
Old May 17, 2017 | 02:46 PM
thisguy65's Avatar
I believe this is it
HX35 wastegate mod writeup - Dodge Cummins Diesel Forum
