Is this how my turbo should look?
Old Sep 23, 2016 | 12:08 AM
01 24v's Avatar
Default Is this how my turbo should look?
Turbo works great sounds even better just wonderi g while my truck is sitting if this is how it should look
Attached Thumbnails Is this how my turbo should look?-20160922_134231.jpg   Is this how my turbo should look?-20160922_134245.jpg
Old Sep 23, 2016 | 04:11 AM
gh0stman's Avatar
It looks pretty dirty. I would try to clean it if you could. You may have a oil seal going out dumping oil into the intake.
Old Sep 23, 2016 | 12:22 PM
01 24v's Avatar
Ok thanks man! Ill try my best to clean it! And by seal do you mean the steel hose or which area would i start from to replace things?
Old Sep 23, 2016 | 12:45 PM
gh0stman's Avatar
The seal between the compressor/turbine. If it leaks oil you run into the chance of having a run away. Plus it traps dirt and junk and wears out your turbo quicker.
Old Sep 23, 2016 | 03:31 PM
01 24v's Avatar
Can that be replaced or would i need a new turbo?
Old Sep 26, 2016 | 04:03 AM
gh0stman's Avatar
You can replace them. Make sure you buy a rebuilt kit from a Holset authorized place. The cheap Chinese kits are junk.
