Heater fan speed keeps going out
Old Sep 20, 2016 | 07:25 PM
mpcampers's Avatar
Default Heater fan speed keeps going out
any one have a issue with there heater fan speed getting hot and going out?? any Ideas I have replaced it 4 times. with no luck, cant find what is the cause...???
Old Sep 20, 2016 | 10:41 PM
kerley's Avatar
Did you replace the relay. It is on the left side of the fan motor, just follow the wires from the blower motor, the relay is very close to the firewall and you need a short Phillips screwdriver to get it out. There are two screws holding it in place. I did mine this week and it is a very tight place, Good Luck
Old Sep 22, 2016 | 08:00 PM
mpcampers's Avatar
yes, I have replaced it 4 times it gets hot and go's out in min. there is something more to it. I just have no idea.?? but thanks for the reply...
Old Sep 22, 2016 | 08:15 PM
kerley's Avatar
This is what my Mechanic told me, and it makes sense.
As the HVAC fan motor turns, in time the bearings and brushes wear to the point that they drag [normal wear over time] with drag it requires more amps to operate freely as it should, and gets hot causing the relay to fail. If my Mechanic is correct then you need to replace the HVAC blower motor and the relay together, that's what I did and I'm up and running as it should. Good luck.
Old Sep 26, 2016 | 05:30 PM
mpcampers's Avatar
sounds like it may work, if I don't get any more ideas. I think I may try it..
thanks
Old Sep 27, 2016 | 01:53 PM
WBsBADBOY's Avatar
I have a 2000 that used to do the same thing...or so I thought it was heating up and stopping. Turns out that there is a molex connector under the heater box on the passenger side that was shorting out. you should be able to see it easily. The reason I never saw it was that the burnt side was facing up and I didn't bother to inspect it any better.
Hope this helps.
Smitty
Old Sep 27, 2016 | 03:59 PM
mpcampers's Avatar
Question
Hope this helps.
Smitty
thanks I will take a look, maybe it will be that easy...???LOL
Old Oct 3, 2016 | 08:11 AM
mpcampers's Avatar
well I checked out the molex connector's they all look fine. was checking the motor after running just a few mins. it was very hot to the touch. not the housing but the motor inside? I don't know if that is normal. the vent tube is connected and blowing air.
Old Oct 3, 2016 | 04:41 PM
mpcampers's Avatar
I installed a new fan motor the old one was dragging and full of dirt and grime. so far so good...???
Old Oct 16, 2016 | 03:59 PM
mpcampers's Avatar
well it's been a week and everything is working good, so the fan motor must have been bad. very dirty inside and out.
