Isspro Gauges
Old Jun 1, 2008 | 10:21 PM
dieselsmoke74's Avatar
Default Isspro Gauges
how do u hook a isspro fuel pressure gauge up to your stock fuel set up on an 02 dodge
Old Jun 1, 2008 | 10:36 PM
Did you buy a kit with a fuel pressure isolator?
Old Jun 1, 2008 | 10:43 PM
Diesel Dummy's Avatar
need a tapped banjo bolt also.
Old Jun 2, 2008 | 06:10 AM
yes i have an isolator, i dont understand that whoile deal either the directions suck!
Old Jun 2, 2008 | 12:05 PM
dukeboy_318's Avatar
on an 02, i believe you unbolt the banjo bolt on the inlet side of the VP44, then you replace it with the tapped banjo bolt that comes in the kit, torque it done to specs(cant remember off the top of my head) and then screw in the sensor into the tapped banjo bolt, hook up you wires, bleed your fuel system and start the truck. should be pretty simple, i know those instructions they give really do suck.
Old Jun 2, 2008 | 02:47 PM
Make sure you get as much of the air out of the tube that goes from the Isolator to the Fuel Pressure Gauge.
Old Jun 2, 2008 | 04:56 PM
Bucket Truck's Avatar
There is a check valve next to the bango bolt that you can remove the valve stem from and tap onto the pump right there.
Old Jun 2, 2008 | 09:02 PM
For a basic install - have a look at this thread:
https://www.dieselbombers.com/5-9l-2...e-install.html
Old Jun 2, 2008 | 09:58 PM
where can u get this banjo bolt and the valve at? they are not in the kit
Old Jun 2, 2008 | 11:06 PM
A tapped banjo bolt is available from ANY of our Sponsors or from any performance diesel shop.
If you cant find one - you can get tapped banjo bolt and a needle valve from here (as well as just about any other fitting would ever need):
www.vulcanperformance.com
