Hard start and shut down 1st gear very low ....
Old Aug 25, 2016 | 02:25 PM
99 5.9 cummmmmins's Avatar
Default Hard start and shut down 1st gear very low ....
When i start up hot or cold it takes some time i realize when i touch the pedal just a tad it fires instently and on shut down it is really shutting down hard new to this 99 5.9 5 speed cummins please any help is appreciated.
Old Aug 26, 2016 | 04:25 AM
gh0stman's Avatar
What is your fuel pressure?
Old Aug 26, 2016 | 09:51 AM
Default Idk
How could i find that out?
Old Aug 26, 2016 | 09:56 AM
gh0stman's Avatar
Since you don't have a fuel pressure gauge in cab. You can get a test gauge and connect it to the inlet of the VP. There is a treaded valve. You want to see more than 10 psi (bosch spec). I personally wouldn't feel comfortable with less than 15. If you still have the stock lift pump I am sure that your pressure drops are pretty big.
