wiring
Old Jul 15, 2016 | 09:43 PM
timetester's Avatar
Question wiring
I did Body & point work for almost 40 years, I don't know anything about Diesels...
1989 Dodge D250 Cummins Turbo 12 Valve Automatic 2 speed... All stock... The Battery was "bolted down" backwards and burnt out 99% of the wiring - Engine - Dash - Lights... I had 2 batteries " Blow-up ", fireball shot out and sounded like a bomb... After a year of patching wires and replacing relays... I finally " Cut every wire from the engine & dash " the only wires left is the Alt and I don't think that is hooked-up because I took out the PCM...
It's Hot-Wired, FSS to battery - Run Starter solenoid to battery... I hope it don't mess up anything...
Old Jul 16, 2016 | 12:42 AM
Jet A Fuel's Avatar
Welcome to Diesel bombers! great thing about the 12 valve's you could hit the starter with no other wires attached to the engine and it will start . great motor tried and true.
