97 3500 no charge no tach trans won't shift
Old Jun 30, 2016 | 07:38 PM
helifixer's Avatar
Default 97 3500 no charge no tach trans won't shift
I have read hundreds of post, tested everything I can,
after about 50 hours of wiring, sensors, cleaning grounds, cleaning battery terminals, banging my head on the radiator, found the 5V signal from pcm was only about 1.5V bought reman. computer put in truck,now getting 5V. heard a click under driver side battery first time I turned key on. removed tray turned key back on and cruise control servo was clicking. dis connected connector, started truck everything worked.
started it this morning 1st start all good, second start nothing works!. new ess, checked gap.
one thing I did notice when I have my DMM hooked to the ground wire for the sensors with key off I have 0.1 ohms, key on it goes to 6.5 ohms with both computers.
Old Jul 2, 2016 | 06:43 AM
JBearSVT's Avatar
My guess would have been PCM. Why did you disconnect the cruise servo? Because it was clicking? Hm.
Old Jul 2, 2016 | 08:50 AM
helifixer's Avatar
yeah it was clicking and I had never heard it do that before.
asd relay was also clicking, swapped it with another relay and that stopped.
ran truck 2 times all good now back to nothing working.
Old Jul 2, 2016 | 04:57 PM
JBearSVT's Avatar
Old Jul 2, 2016 | 11:11 PM
Jet A Fuel's Avatar
I have heard that if you have a tilt steering column and use it alot getting in and out of the truck that wires sometimes chafe in that bundle. the cruise control wire turn signals etc.. sounds like you have checked most of the stuff under the hood. Also check your batteries for good voltage.
Old Jul 3, 2016 | 08:48 AM
helifixer's Avatar
had the column apart checked wires, new batteries, spotless terminals, constantly checking battery voltage.
Old Jul 6, 2016 | 01:57 PM
helifixer's Avatar
anyone have a diagram of ground points? I am thinking I might have a problem at G152 of G125
