96 12 valve cummins
Old Jun 22, 2016 | 08:51 AM
9612valvefummins's Avatar
Default 96 12 valve cummins
What mods do I need to do to get around 450hp and still be able to pull a trailer. Motor does not have a turbo and not wanting to spend over 1000 dollars on just turbo. Any help would be appreciated
Old Nov 6, 2016 | 09:05 PM
97cummins's Avatar
What happened to the turbo on your 12valve?
As for wanting to get to 450hp, you would have to spend a bit for the 450hp.and you will need the turbo.
Old Nov 9, 2016 | 09:51 AM
wpg6.5's Avatar
your in the wrong game to not wanna spend 1000 on a turbo. a box borg warner with out a wastegate is less than a grand but then you must know what your doing tuning wise and how to pick the correct ar turbine housing. as for 450, basically tuning, a 3 or 4 gsk, and a turbo, you may need injectors or dvs. but 450 should be doable on mostly stock fuel parts.
