I need help!
Old Jun 9, 2016 | 06:41 PM
Cumminsgotmecrazy's Avatar
Default I need help!
I have an 00 cummins. New starter, alternator, batteries and still showing low voltage. Checked ground and it was tight and still check gauge and voltage is bottomed. What else could it be?
Old Jun 10, 2016 | 04:35 PM
02cummins95's Avatar
maybe you have bad cables? not real big on electrical but its a thought
Old Jun 12, 2016 | 05:05 AM
Duallybully's Avatar
Whays the voltage if all wires test good cont and voltage with koeo ..try a new alt I had this problem yesterday
Old Jun 13, 2016 | 04:37 AM
gh0stman's Avatar
If the cable ends are worn out you will have issues with charging. Also the slightest bit of corrosion makes these trucks do weird things as well.
Old Jun 16, 2016 | 10:23 PM
Thanks for all the advice! I took it to the shop and it was an electrical problem at the fuse box. $500 later and she's purring again!
