2001 Chevy Express 3500 6.5L Diesel Head Gasket?
Old Mar 30, 2016 | 02:39 AM
mrschultz's Avatar
Default 2001 Chevy Express 3500 6.5L Diesel Head Gasket?
hey guys,
anyone here ever complete a head gasket job on one of these express/savana diesel vans?? I'm facing the inevitable of replacing mine, but mechanics i've spoken with say it's a massive job, almost to the point where they don't even want to do it.
they are charging anywhere from 3500-4000 just for the gasket job. I don't have that kind of money! so i'm tackling this myself.
just wanted to know if anyone here has done one, successfully
thanks!
Old Mar 30, 2016 | 09:29 AM
HeavyChevy95's Avatar
Im sure many here have successfully replaced headgaskets, on there trucks or SUVs. Vans however are very different animals, 20 pounds of pooh stuffed into a 5 pound cashole.
Helped a friend R&R a SB350 out of his chevy van years ago. With all the stuff mentioned below out of the way, it wasnt to difficult but doing an in-frame on a 6.5TD in a van. No matter what, s'its gonna be hell on the lower back.
I suspect removing the entire front end, grill, coolers, AC, radiator support, radiator, seats, doghouse, and all else those task entails ought to lend itself to a successful head gasket job on a van easy 'nough.
Given several days to commit to the project so that you can take your time, double check everything as you go, dont rush s'it, its a doable DIYr project provided the proper instruction, guidance, tools, equipment and some helpful preparations beforehand...
Take lots of pictures before you start disassembling anything and bag and tag everything so nothing is forgotten or misplaced...
Reused valve train components should be reassembled in the same position in which they were removed eg hydraulic lifters, pushrods, rocker arms and/or rocker assemblies. Never reuse the oem TTY headbolts, replace them with new bolts if not head studs.
Avoid using gaskets when ever possible, especially on the rocker arm covers, suggest you use RTV sealant only.
Aside from R&Ring the injection hard lines from the back of the IP, do not loosen unbolt, move, remove or adjust the IP itself, otherwise you'll need to to do TDCO or KOKO procedure too.. Just complicates matters is all..
Cant help you with specific 'van manuals, might check e-bay. Good Luck..
Old Mar 30, 2016 | 11:08 AM
mrschultz's Avatar
wow thank you so much for all the advice!
do the ARP bolts I keep reading about really make a difference? also, does the turbo have to come off and if so, is there anything special I should know about it before removing it?
is there anything else that should be checked or replaced while ripping this motor apart? any typical parts that should be replaced or recommended to replace? i heard something of injection cups and how they should be tested, any tips on that?
thanks again, that's a lot of help! and by the way, i'm giving myself a month (or longer), the part that scares me the most I guess is the re-assembly and making sure i don't forget where things go back. but that's something I always worry about, but seem to remember when it comes time to put things back together.
i've done work on other vehicles before, typical troubleshooting and repairs, but nothing to this level! i'm excited to get started on it. good idea about the pictures, and labeling.
cheers!
Old Mar 30, 2016 | 11:29 AM
Josh Haynes's Avatar
for what its worth the manual says pull battery, drain coolant, remove doghouse, remove air cleaner and intake duct, remove accesory brackets, remove heater hoses, remove thermostat cross over, remove turbo charger, remove lower intake, remove valve cover and rocker arms, remove exhaust manifolds, remove head bolts and heads. reassembly is where it gets complicated.
some notes, head studs is a no-go in vans not enough clearance to assemble properly.
pushrods have a hardened end that is marked with paint that must be at the top.
Gm says the valves and pistons are too close together and you cannot surface the heads.
pull the lower headbolts first to aid in draining coolant from block before pulling uppers.
DO NOT UNDER ANY CIRCUMSTANCE REUSE HEAD BOLTS
Be careful tightening rocker assembly down, valve damage is possiable if the crank is not in the proper position
Also black rtv has its place in engine assembly but it is not a gasket replacement. use the right gaskets.
Old Mar 30, 2016 | 11:55 AM
mrschultz's Avatar
Hey Josh thanks for the info-
I had a 1997 express diesel beforengine and purchased a service manual (2 massive manuals about 10000 pages. Do you know if the 2001 6.5l is the same ? I know they changed motors in 2001 built diesels to the 6.6.
Thanks!
Old Mar 30, 2016 | 12:02 PM
6.5 is 6.5. thermostat cross over changed in 96 with the water pump. they added a turbo back in 90 (?), went from mechanical pump controls in 94 to electronic pump controls for 95. little things changed over the years but if you have a 6.5 manual from any year it should be helpful but maybe out of date. So if you have an older one i would use it for refrence but double check torque specs and stuff with more modern information.
Old Mar 30, 2016 | 09:09 PM
Tanman_2006's Avatar
If you resurface the heads they make thicker head gaskets to accommodate that to some degree.
ARP makes a TTY bolt that is better than OEM.
Leroy Diesel and Unique Diesel can get those parts.
Leroy sells p400 and optimizer heads and whole engines too BTW. Very helpful guy, Google his site
Old Mar 30, 2016 | 10:36 PM
mrschultz's Avatar
i'm looking at the ARP head bolts and they are $255 plus shipping USD
is there really that much of a difference in the head bolts? the fel-pro bolts are about $50 for both sides.
I know the saying "you get what you pay for"... but how much more do you really get with ARP parts ?
cheers
Old Mar 30, 2016 | 10:37 PM
mrschultz's Avatar
I actually saw the ARP stud kit for like almost $600 USD on ebay, wow!!! what's the difference guys? is there really that much advantage using the studs over the bolts?
Old Mar 30, 2016 | 11:42 PM
I told you 2 of the best places to shop. Call either of them for info on prices and parts. Both will shoot you straight, both have been in the game a very long time.
http:// http://leroydiesel.com/produ...-2-6-5-diesel/
http:// http://www.uniquediesel.com/repair.html
