Best towing turbo?
Old Mar 24, 2016 | 10:46 PM
six speed's Avatar
Default Best towing turbo?
I'm running my stock hx35 on my 97 12v. I've took the fuel plate out and put in a 3k gsk and boost elbow. The truck is running pretty good and I have to replace the clutch before I do anything else, but I feel like the turbo is being a hindrance. I've got it set up so that it doesn't smoke much and egts aren't to bad, but I can easily hit 36-38 psi of boost. According to a previous post 40 is max that you want to push this turbo. Would the 3.5 inch boost tube and intake help? What do you think is the best towing turbo? I tow almost daily anywhere from 5000 to 20000 lbs. I've got the bd supermax on my dura max and it made a world of difference. I was looking at the bd super b or the cpp 62/65 12.
Old Mar 25, 2016 | 07:43 AM
94 12valve's Avatar
Of the two you listed any 62/65/12 would be a good choice for what your after. Another cheaper option would be a good he351, would have to redo a little bit of intake piping and the exhaust piping to make it work tho.
Old Mar 25, 2016 | 08:42 PM
six speed's Avatar
Redoing the piping wouldn't be a big thing. I already built the exhaust once. I had been reading about the he351 on here also. I think I can come up with one of them. What are we talking about for spooling, egt control, and peak boost pressure? By how much will it out perform the hx35?
Old Mar 25, 2016 | 10:42 PM
six speed's Avatar
I found a video of an he351 vgt on a 24 valve. Would this work on the 12v as well? It had a toggle switch for the exhaust brake. That would be nice when towing.
Old Mar 26, 2016 | 07:50 PM
94 12valve's Avatar
Yes it would work on a 12v also just requires some fab work to make it work. The he351 would spool like a stock hx35 but with more top end.
Old Mar 29, 2016 | 03:42 PM
six speed's Avatar
Sounds good. What about the 3.5 inch intercooler line and intake?
Old Mar 30, 2016 | 10:23 PM
six speed's Avatar
Another question, if you were to run an he351 vgt on a 12v could you run a pacbrake load leash? Would it work? Why or why not?
Old Apr 25, 2016 | 05:35 PM
GasItOut's Avatar
isnt the pac brake made to work with the 24v head? im not sure how you could put it on a 12v
