Low boost
Old Mar 20, 2016 | 06:42 PM
ebbtide357's Avatar
Default Low boost
Seems like my boost is too low lots of smoke even on 3x3 on edge comp what's the easiest way to find if its leaking somewhere if you look at my sig it should jump to 30 I think easy unless the gauge is wrong or hooked up wrong thanks
Old Mar 21, 2016 | 06:39 AM
gh0stman's Avatar
You need to check for boost leaks and go from there.
Old Mar 21, 2016 | 07:51 AM
ebbtide357's Avatar
Thanks ghostman I'm trying to make something up to pump some air into the turbo than get some soapy water in a bottle I can't find the link anywhere
Old Mar 21, 2016 | 07:53 AM
gh0stman's Avatar
look up DIY boost leak tester. I know on another forum I am on there are a ton of DIY articles on the subject.
Old Mar 21, 2016 | 04:10 PM
ebbtide357's Avatar
Default Boost
Ok I made a boost leak tester using a small 12v air pump can't get past 6 lbs don't hear anything leaking the rubber boot swells up a little going to run to friends house tomorrow for his bigger compressor I've seen video of people doing it with small pumps maybe I'm doing something wrong? Seems pretty straight foward I even had a bottle of soapy water ready tomorrow's another day
Old Mar 21, 2016 | 05:54 PM
ebbtide357's Avatar
Default Couldn't wait
Went out with soapy water in a spray bottle got big bubbles while idling truck on boot right below turbo I also turned in my adjustable elbow some going to get a new adjustable elbow this one is real hard to turn got to cold I'll tighten that boot up tomorrow see what happens
Old Mar 22, 2016 | 04:49 AM
gh0stman's Avatar
You need to at least get it up to 20 lbs of air.
Old Mar 22, 2016 | 05:47 AM
ebbtide357's Avatar
I used a 12v tire pump thought it would be enough unless the leak is bigger than I realize could the waste gate be a problem is an hx 35
Old Mar 22, 2016 | 11:54 AM
ebbtide357's Avatar
Default All good
One loose boot 😀 thanks guys 30 lbs no problem
Old May 3, 2016 | 07:50 PM
5.9 cummins1983's Avatar
i have low boost problem also can anyone help most i can get is about 16 hit 20 one time thats it. checked all boots and clamps for leaks they seem good runing comp box on 2*5
