start but won't run problem
Old Mar 13, 2016 | 08:24 PM
stinsonv77's Avatar
Default start but won't run problem
tried all the usual cures to no avail . since it would start and sometimes run for a mile or two i ignored the fuel shutoff solenoid. but once i wired it on it ran fine. the short drives must have in its failing stage. but it never lost the ability to start and then die.
Old Mar 14, 2016 | 05:42 PM
51Hudson's Avatar
I'm lost on whats wrong with your truck.
You tried the usual cures to no avail, like what the fuel shut off solenoid? There can be multiple reasons the solenoid is failing like one the relay, that's closest to the firewall, can be bad. Second the blue wire that's on your battery can be corroded causing it not to get proper resistance causing the fuse in the dash to pop.
Still I'm trying to figure out your question, some things about your truck would help too. Do you have a fuel pressure gauge?
Old Mar 14, 2016 | 06:55 PM
stinsonv77's Avatar
sorry for the poor communications. it was a statement not a question. i had chased "start won.t run " thru the internet and no one had mentioned fuel shutoff solenoid so i wanted to add that to usual suspects. would have saved me a lot of time. i have no power to solenoid with key off and 12 volts when key on so presume relay etc good truck runs fine if you manually close solenoid. new part on the way. thanks for your concern i am new to this truck and to mechanics in general so i will take all the help i can get.
Old Mar 15, 2016 | 12:31 AM
51Hudson's Avatar
Hey no problem, 12 valves are pretty much bullet proof except for the trans and body
