Rim Question!
Old Mar 12, 2016 | 08:46 PM
Cummins75's Avatar
Default Rim Question!
I'm wanting to buy a used set of rims and tires, there like 35x14x20 fuel hostages. Came off an 02 Chevy 2500 hd. There 8 lug, they will fit on my truck right? Just because they came off a Chevy doesn't make a difference does it? And sorry I'm not a tire/ rim expert haha thanks in advance
Old Mar 13, 2016 | 09:30 PM
six speed's Avatar
The bolt pattern should fit. Trying to fit 35's on a factory height truck I think will require a little trimming in the front. And depending on the offset and back spacing you may have rubbing issues when turning. I think I would put one on the front and see how it worked if I could.
Old Mar 14, 2016 | 12:01 PM
Cummins75's Avatar
Yeah that's what I was worried about the most was the rubbing, but the deal fell through anyway. At least for now how high would I have to lift my truck to clear 20x14? Like 4 inch?
Old Mar 14, 2016 | 01:08 PM
six speed's Avatar
It's not the height of 20x14 that rubs its the width. unless their spaced way out the tires will rub when you turn the wheel. To clear 35's i would say at least 3 inches of lift, but I'm not positive.
Old Mar 14, 2016 | 10:42 PM
Cummins75's Avatar
Ya that's true, that's another question! Does anyone make a lift kit for a 12v cummins. I can't seem to find any lift kits for 94-97's
Old Mar 15, 2016 | 09:15 PM
six speed's Avatar
Yes, I know that bds does make a 4 and 4.5 inch. Cpp has them but they're expensive.
Old Mar 16, 2016 | 09:58 PM
cavalierx's Avatar
I believe Superlift has 5" kit too, remember a neighbor here done on his 1999 Ram 2500.
Old Mar 19, 2016 | 06:49 PM
Cummins75's Avatar
I'll check em out thanks guys for all the help. Also another question what you guys spend on a set of fuel hostages 20x14 with 60% tread left on a set of irocks. I've got the guy at 1800 but seems a little pricy still
Old Mar 19, 2016 | 07:35 PM
JBearSVT's Avatar
Only place I would go for 2nd gen suspension is Dodge Off Road.
Old Mar 20, 2016 | 06:39 PM
Cummins75's Avatar
I just checked dodge off road...there pretty proud of there stuff. Super lift makes a 5 inch lift for about 800.
