Idle Problem
Old May 27, 2008 | 11:42 AM
bway1341's Avatar
Default Idle Problem
My wifes 05 idles fine the it idles rough then its fine again. THere is a little white smoke whenits started but that it. Does anyone know what my problem maybe?
Old May 27, 2008 | 02:25 PM
staarma's Avatar
Have you tried the key trick yet to see if any codes are present? Some guys have reproted cam/crank sensor problems. Injectors can't fix themselves so I don't think that's where your problem is. A faulty sensor can go in and out depending on the situation and the failure.
Old May 27, 2008 | 03:05 PM
Wyatt Earp's Avatar
That or a crappy ground.
Old May 27, 2008 | 07:56 PM
bway1341's Avatar
Cool guys thanks I am going to change the fuel filter cause it seems like it starving for fuel. I am sure the pump needs upgrading cause its stock. It only has the p0483 code the clutch fan speed code. I will check my grounds and change my filter I think i will check the fuel psi also.
Old Jul 5, 2008 | 12:35 PM
Imacumminz's Avatar
bway, did this problem go away?
This could be a bad injector leaking fuel into the cylinder when the motor is not running. When you start it, it runs rough and has white smoke from the exhaust until it burns the excess fuel.
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
xbreaselx814
Dec 7, 2014 06:59 AM
hunt4beer
Nov 15, 2014 09:06 AM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
