Fuel drian please help!
Old Feb 16, 2016 | 07:21 PM
lines24v's Avatar
Default Fuel drian please help!
Hello everyone! Just last week I had the vp44 go bad and had it replace now if it sits for a 8hrs or so it will crank and crank before starting. when it does sit there's no leaking fuel and I've checked the fuel system over but no luck on finding a leak any ideas. Thanks!
Old Feb 17, 2016 | 05:46 AM
gh0stman's Avatar
Did you check the return banjo bolt on the back of the head?
Old Feb 17, 2016 | 07:41 AM
lines24v's Avatar
Yup check the return banjo bolt and it tight
Old Feb 17, 2016 | 07:44 AM
gh0stman's Avatar
If there are no leaks visible there may be air getting into the system pre-lift pump.
Old Feb 17, 2016 | 08:47 AM
lines24v's Avatar
Ok thanks I'll see what I can find on the lines today
Old Feb 21, 2016 | 09:18 AM
Greenbeast's Avatar
By "pre lift pump" do you mean the lift pump before the injector pump? I have had the same issue and just lost another injector pump.
Old Feb 21, 2016 | 11:25 AM
gh0stman's Avatar
Pre lift pump means fuel tank to pump. What is your fuel
Pressure at?
