Scary engine noise please help
Old Feb 13, 2016 | 10:01 PM
78cummins91's Avatar
Default Scary engine noise please help
Hey guys. I'm building a 65 ford f250 with the 1990 12v 5speed 4x4. I know its not 2ND gen but 1st gen guys never responded. I bought a used engine for the project. Put a new injection pump on it and I have around 4 or 5 hours of run time on engine. Not until recently I built the exhaust and and now I can hear some sort of engine noise, like a tapping. I started cracking injectors and once I got to #6 it went away. So I put some new injectors in it and it still makes the noise. The noise is real loud at cold start up. Once the engine start warming up I don't think I can hear it anymore. You can't hear it from right on top of engine. You have to be standing by side of truck or in cab. Also I'm getting a tiny metallic sound from my bellhousing. Do you think a cracked flywheel or bad pressure plate could be causing engine noise? I have plenty of oil pressure 60-40psi, I already adjusted my valves, motor runs great, no misses at all, I'm just hoping I'm not losing a bearing or wrist pin. I pulled oil filter and there wasn't any metal in it . Mabe a lifter? Any input or ideas would be great thank everyone!
Old Feb 13, 2016 | 11:10 PM
six speed's Avatar
Mine had a ticking noise in the bell housing a while back. I figured that the clutch was going out but it quit ticking and everything seems to work fine still. I haven't had it apart to look at the clutch yet but probably will soon.
Old Feb 14, 2016 | 02:04 AM
I'm pretty sure my bellhousing noise is just a dry or bad though out bearing. It doesn't make any noise when clutch is pushed in. So it's probably in the engine. The truck engine was originally in was wrecked and it sat for years before I got it. I'm hoping it will clear up once ran awhile.
Old Feb 14, 2016 | 06:41 AM
JBearSVT's Avatar
Exhaust leak?
Old Feb 16, 2016 | 02:19 AM
Slim Whitey's Avatar
Stole the thought out of my head Jbear.
Old Feb 16, 2016 | 05:35 AM
JBearSVT's Avatar
I only meant to borrow it, but once I had it in hand I... got attached to it.
