Timing cover torque specs???
Hope This Helps But This Is What I Found Cummins Wise
Bracket, rear, engine lifting ---------------------57
Connecting rod---------------------------------26, then 52, then 74
Crankshaft damper & pulley---------------------92
Exhaust manifold to head-----------------------32
Flywheel adapter housing, Aluminum-------------44
Flywheel adapter housing, Iron------------------57
Flywheel housing cover-------------------------18
Flywheel to crankshaft-------------------------101
Gear housing timing cover-----------------------18
Injector retaining nut---------------------------44
Injector fuel drain banjo screw (in injector)-------72 in-lb
Intake manifold cover---------------------------18
Intake jacket water aftercooler to head----------18
Main Bearing------------------------------------44, then 88, then 129
Oil Pan------------------------------------------18
Rear seal mounting cover------------------------48 INCH/LBS
Rocker arm support------------------------------18
Transfer pump mounting--------------------------18
Turbo to manifold--------------------------------33
Valve cover-------------------------------------18
VE Bosch injection pump:
Solenoid, fuel shut off---------------------32
Solenoid, KSB-----------------------------16
TORQUE CONVERSION NOTE: 12 INCH POUNDS = 1 FOOT POUND
quiksilver1j
Jul 30, 2015 12:41 PM
carid
Diesel Bombers Sponsors
Jul 16, 2015 05:11 AM
SMatyac
Nov 15, 2014 07:35 PM
