2,500 to spend any suggestions
Old Feb 4, 2016 | 09:14 PM
bigjohn's Avatar
Default 2,500 to spend any suggestions
I have a 99 dodge ram 3500 dually with 67,000 miles bone stock except for turbo back 4 inch any suggestions as to what I should do? Bigger tires ,lift,edge injectors, not sure what I should do any help would
be great
Old Feb 5, 2016 | 07:45 AM
24vCumminsGuy's Avatar
Default Upgrades
I have a few suggestions on some upgrades for you. If you still have the factory lift pump I would strongly recommend upgrading to an air dog or fass fuel system to ensure you have proper fuel pressure to your vp44 injection pump. The best box/programmer for these trucks is called Quadzilla Adrenaline which adds up to 180hp and you can custom tune your truck to whatever performance/mileage tune your looking for. If your still looking for more performance you could add a set of 100Hp injectors to really make some good power and be able to black out the road with smoke. You can buy a 2.5" lift for the front end for cheap. Or if you just want to make the truck look better instead of performance you could add a 5" Superlift for $700 and some nice tires and rims
Old Feb 5, 2016 | 09:14 PM
bigjohn's Avatar
Those are all things I am thinking of just having a hard time deciding witch ones to do and the VP went out at 45,000 and was replaced along with the loft pump
Old Feb 8, 2016 | 05:11 AM
gh0stman's Avatar
I would upgrade the transmission before throwing any power at it. Also add the lift pump as well.
Old Feb 13, 2016 | 01:22 PM
Monstermaker's Avatar
Hold on to your money and save $2500 more, then get a transmission!
Old Feb 15, 2016 | 09:40 AM
jkidd's Avatar
Quadzilla Adrenaline, Trans upgrades, lift pump, and injectors with a turbo.
What is your HP goal?
