Throttle body plate
Old Jan 17, 2016 | 04:36 PM
6OGabe's Avatar
Default Throttle body plate
Hi I have a 2004 ford 6.0L Throttle body plate is not opening when plugged in but when I unplug the throttle plate motor my truck seems to run ok but my check engine light is on.Should I buy a new throttle body or should I just remove the plate? If I remove the plate and plug it back in will the check engine light still stay on?
Old Jan 17, 2016 | 08:44 PM
Adrenaline junkie's Avatar
Get an 05 up elbow, it will remove the valve and aftermarket ones flow a little better
Old Jan 17, 2016 | 08:53 PM
6OGabe's Avatar
If I get a 05 and up elbow I will not be able to plug in my sensor?Will my check engine still be on with the 05 elbow because I can't plug in my throttle body motor?
Old Jan 19, 2016 | 08:27 PM
6OGabe's Avatar
If your trucks computer gets a update do you need to reprogram the tsp sensor on the throttle body or is it just plug in and play?Need some help thanks
