Fuel lag
Old Jan 6, 2016 | 12:44 AM
Countryroughneck's Avatar
Default Fuel lag
My 98 Cummins is acting really sluggish. It runs fine starts normal but when I push the peddle driving down the road the fuel peddle is firm and it dosent get up and go any more. It use to roll the coal but now when I mash it it don't do any thing. Any ideas?
Old Jan 6, 2016 | 06:40 AM
wpg6.5's Avatar
What is done to the truxk? Rolling coal doesn't particularly scream horse power. But it sort of sounds like you may have a fuel pressure issue. Due to a failing Lp or ofv. But there are other symptoms of thay aswell.
Old Jan 6, 2016 | 11:12 AM
94 12valve's Avatar
check the signal line going to your AFC make sure its not leaking or broken. That is where I would start followed by the shutdown solenoid. Most likely one of these two things is your problem
